New Rotor keep making weird noise when braking
Hey guys i just install some drill Password JDM Rotors prob a month ago, and most of the time when i let the car roll and slightly brake, the brake keeps make this grinding noise.... i don't really know why its doing that..... is it because of my pads? I'm using duraflex pads from auto zone or what? cuz on my stock rotor, everything seems fine when driving...... thanks for all the suggestions.....
Your rotors formed your pads into a "grove" if you know what im saying. this happens if you dont machine/ flip your rotors when you put on new pads. so your new rotors are perfectly "straight" while your pads arent. if you put a couple 100 miles on it, it should go away.
example
"Pad"
old rotor
new rotor
example
"Pad"
old rotor
new rotor
example
"Pad"
old rotor
new rotor
example
"Pad"
old rotor
new rotor
That may be normal then. I first put drilled rotors on the front and they were quiet, and then I put on some drilled and slotted rotors on the rear and the brake system got noisier after that, with low pitch groaning.
Alfredo
Jul 7, 2003 12:38 AM
