New Steering wheel install - NOT centered!
So I installed a new steering wheel on my S. My car had a perfect alignment done about a month ago (below). My original steering wheel was perfectly centered (so don't think it is a tire pressure issue either). I used a steering wheel puller and marked the center point position on the rack.
When I installed it the first time and took it out on the road for a test drive my wheel was slight tilted to the right. I was like ok, no problem. I redid the process and adjusted the wheel one notch\spline to the left of its current position. When I test drove it the second time, the wheel was offset to the left (more severely than it was offset to the right - maybe due to road cambers). So I was like ok, I redid this a third time thinking that if I shift it one more notch\spline to the right, I should be dead center. Well guess what, I took it for a test drive a third time and it was back to the same situation as the first test drive (i.e slight tilted to the right, maybe a few degrees off). So it seems I am stuck between two splines that either make the wheel to far off center in one direction or the other. Any ideas of how I can fix this without messing with alignment. The new steering wheel is a re-trimmed piece from a 3rd party. Could there be something wrong with the used wheel. Is there a center position marker on the steering column (I couldn't tell any difference between the splines). New wheel: http://i33.photobucket.com/albums/d9...0wheel%201.jpg Driving down (Almost straight road with minimal camber) wheel is slight turned to the right (point to just about 1 o clock) http://i33.photobucket.com/albums/d9...er%20wheel.jpg alignment done about 25 days ago http://i33.photobucket.com/albums/d9...n/IMG_9449.jpg |
Get the car realigned. Unless that's not an option?
Steering wheels are molded plastic over a metal skeleton. Manufacturing tolerances exist. Your situation is not a surprising one. |
Very common when swapping steering wheels, I have the same situation with a custom wrapped wheel. Re-aligning the car is the only way to centre the wheel.
Put your old steering wheel back and you will know whether the new steering wheel is causing the issue.
The teeth on the steering wheel aren't fine enough to correct this. It's happened to me several times before. Usually a fit like this has around .020" of gap between mating teeth. What I like to do is slide the steering wheel on and tilt it towards the direction you want to fix (notice how the wheel can whobble left/right before you tighten it) and have someone hold it there while you tighten the nut.
The only way to fix it perfectly is adjust your tie rods. If you do it correctly, you won't mess up your alignment. Mark both tie rods with white-out, then do a 1/4 turn on each. Check steering wheel and repeat until you're satisfied. |
Originally Posted by roel03
(Post 24424687)
Originally Posted by kasher_khan
(Post 24424692)
Adjusting Tie rods is what I was thinking. Removing the steering wheel is scary. Each time I use the steering wheel puller, it seems I'm messing up the steering column (can't use the puller pad, the S2000 hole is too small for it). Also it comes unlose with a lot of force, I have no idea how people are doing it on youtube with just elbow grease.
When I swapped steering wheels they had to adjust both toe rods to get the angle right. Just take it back in for realignment.
Nice steering wheel - I want to add [do not] re-position your steering wheel, that is not the correct way of fixing the alignment issue with it. Take it back in and have them align it so it is at a perfect 12 O'clock.
Originally Posted by OneSilverS2k
(Post 24425871)
I spoke to my body shop. They said they can't mess with the toe without doing a complete realignment (like most have recommended here). Too bad it costs $150 at my shop (this is my third on in three months :) Maybe they'll discount it. |
