Sponsored by: CARiD
Nitrous
Old Jul 14, 2008 | 04:09 AM
Tjs S2k's Avatar
Default Nitrous
Ok im seriously thinking about doing some spray on the s2k. The 4.77s add some pop but it gets pulled by almost everything over 100. It would be nice to have a sleeper setup with a 75 shot. I want a 75 wet shot. WOT switch, Fuel pump. Im not really sure what is all needed with it. I did a search but almost every topic I found everyone started talking about something else. Which kit is the best? 75 wet shot is what I want. How safe is it? (spraying about 1 or 2 times a month... maybe) What would I use for a tune? Aemems or VAFCII? Nitrous experts im calling you out
also since I am replacing my clutch soon, what would be a good one for a 75 shot. I heard the HTG setup is good for 350+ whp?
Old Jul 14, 2008 | 04:45 AM
roy365's Avatar
Nitrous Express wet kit. Anything they make is good. And i dont think you will need to upgrade your fuel pump, I may be wrong though. I dont have N2O on my S2K, but i have a wet kit 100 shot on my Nissan Titan.
You can find a lot of parts on ebay once you decide which kit and the route you want.
Old Jul 14, 2008 | 04:49 AM
Tjs S2k's Avatar
what all do I need tho? What should I tune with? <<<< nitrous noob
Old Jul 14, 2008 | 05:00 AM
roy365's Avatar
Nitrous express makes a great "import" wet kit. Here is the kit I am referring. http://www.nitrousexpress.com/Pages/ImportStage1.htm
you will need a bottle and possibly a window switch or other means to "activate" it. as you can see their kits say you dont need any timing retard or upgraded fuel pumps. you may want to check around on that though.
Old Jul 14, 2008 | 05:24 AM
Q8s2k's Avatar
I have this link saved on my favorites:-
http://forums.s2ki.com/forums/index.php?s=&showtopic=86045
Read what ItalianBucwheat says, it's very helpful..
Old Jul 14, 2008 | 05:35 AM
Tjs S2k's Avatar
thanks guys, I will do some more reasearch when I get home and see where it leaves me. Hopefully I can hang with the big boys, any reccomendations on clutches?
Old Jul 14, 2008 | 05:39 AM
roy365's Avatar
Nice link......like he says, Nitrous Express is the way to go period. Good quality stuff. Josh at Nitrous Express is very helpful as well. If you shoot him an email he will answer all of your questions the best he can.
The hardest part about nitrous is the wiring(well to me).
To the OP where are you mounting your bottle? In the trunk I assume? You will need a purge kit, blowoff tube, and bottle heater as well.
Old Jul 14, 2008 | 10:25 AM
camuman's Avatar
bottle heater is nice, but not needed, purge is also nice, but not needed. but blow down tube is a must if you want to run at the track. you can always use a heating pad for a bottle heater if you have one at your house. works great, just dont leave it on when your not in the car.
Old Jul 14, 2008 | 10:29 AM
roy365's Avatar
A heating blanket? Now that's ballin on a budget there.
The NX kit comes with bottle heater, purge & blowoff tube. Do you have to have them? No, but if you want consistent shots or want to track your car in the 1/8th or 1/4 you will definitely want them.
Old Jul 14, 2008 | 10:51 AM
camuman's Avatar
dual purpose baby! helps ease aches and pains, and keeps bottle pressure up! ROFL.
my buddy was sprayin a 100shot in his vw vr6 24v. man that shot got weaker and weaker unless you had a bottle heater.
