Sponsored by: CARiD
o-ring lube
Old Mar 3, 2009 | 08:49 PM
Boofster's Avatar
Default o-ring lube
What is the best "lube" to use on injector/map-sensor/oil-filter o-rings?
1. Motor Oil
2. Shin-etsu grease
3. Lithium Dielectric grease
4. Urea grease
Old Mar 3, 2009 | 10:24 PM
Chris_Lum's Avatar
i use petroleum grease *corrected* (the clear type) on injectors and motor oil on oil filters. i don't use grease on the map sensor as the surface of the o ring doesn't actually rub against anything in a turning motion (like the injectors and oil filter), it just gets clamped down when screwing in the mounting bolts. Plus, wouldn't want to get any grease in the actual map sensor and screw w/ readings.
Old Mar 4, 2009 | 07:15 AM
ScienceofSpeed's Avatar
Former Sponsor
These o-rings are designed for petroleum. Engine oil would be fine.
Cheers,
-- Chris
Old Mar 4, 2009 | 11:07 AM
rich85tpi's Avatar
Shop manual recommends engine oil for the injector o-rings.
Old Mar 6, 2009 | 04:47 AM
RichV's Avatar
I just put engine oil on my injectors last night when I changed out my fuel rail. Works fine.
Old Mar 6, 2009 | 08:07 AM
Boofster's Avatar
Engine oil it is.
Thanks.
/thread
Old Mar 6, 2009 | 08:24 AM
oyitzpreston's Avatar
petroleum do you guys mean that vaseline stuff? or was that a stupid question
Old Mar 6, 2009 | 08:31 AM
IlleztImportz's Avatar
Old Mar 6, 2009 | 08:41 AM
Sideways's Avatar
Petroleum jelly / Vaseline can be substituted for motor oil in lubricating O-rings.
Old Mar 7, 2009 | 08:54 PM
would it be alright to use vaseline to fix the squeaking on my hardtop?
tehsu
May 20, 2011 12:57 PM
ESCALVANTE
Jan 9, 2008 04:37 PM
s2000_nur
Apr 21, 2006 01:08 PM
naruto
Apr 7, 2005 07:34 PM
hondafirst
Mar 30, 2003 09:46 AM
