Sponsored by: CARiD
Oem hardtop hardware on mugen replica hardtop
Old Apr 18, 2015 | 01:47 PM
mlo1's Avatar
Default Oem hardtop hardware on mugen replica hardtop
I recently bought a mugen style hardtop and I found that the replica braceket is hard to remove and using the soft top latch makes a lot of rattle noise
So i am thinking about getting the oem hardware kit and my question is that is the oem bracket is easy to remove and it makes less rattle noise
Thanks
Old Apr 18, 2015 | 01:52 PM
alphalanos's Avatar
yes the oem hardware is far bettter, it should clamp the top down better and eliminate noise. On my replica top I have to use soft top latches, hard top one dont fit, im not sure if its the same on otehr reps.
Old Apr 18, 2015 | 02:28 PM
mlo1's Avatar
Do you have solution for the rattle noise from the soft top latch or you Iive with it ?
Old Apr 18, 2015 | 03:56 PM
TheSilentSK's Avatar
Live with it. HaHa! Or you can do this: https://www.s2ki.com/s2000/topic/372...rattle-fixdiy/
Old Apr 18, 2015 | 04:05 PM
mlo1's Avatar
Thanks , rattle noise drives me crazy ...
Old Apr 18, 2015 | 04:29 PM
mlo1's Avatar
Btw, with the oem braceket, is it much easier to remove the top?
Old Apr 18, 2015 | 05:37 PM
alphalanos's Avatar
yes the oem bracket are quick release just like the soft top. takes just a few seconds
Old Apr 18, 2015 | 06:41 PM
GS-R Civic's Avatar
go for the oem honda hard top rear rubber seal, makes a huge difference in getting rid of random noises
Old Apr 18, 2015 | 10:00 PM
mlo1's Avatar
So should I get a oem braceket since I always want to be top down when the weather is good and the replica braceket makes it so time consuming. Can the oem braceket fit my replica top with mod?
Old Apr 19, 2015 | 05:07 AM
alphalanos's Avatar
the oem bracket should bolt straight on with no modification
