Sponsored by: CARiD
OEM Wing
Old Nov 12, 2021 | 09:01 AM
JustinBeaty's Avatar
Default OEM Wing
I am going to buy an OEM wing, but I do not know if hardware comes with it. Does anyone know what I would need?
Thank you in advanced.
Old Nov 16, 2021 | 10:35 AM
bunz559's Avatar
Are you asking about the decklid spoiler? Or the raised spoiler offered during the AP2?
If the deck spoiler, there are 4 holes. The 2 outer holes are bolts and the 2 inner holes are nuts that screw onto studs in the spoiler. It could be reversed, I can't remember. But there are 4 total holes. I purchased one a while back to install, but never got to it. If I can remember the research I did, not much information on it, there is a rubber gasket that goes along the outside perimeter of the spoiler, similar to a thin 3M double-sided tape. Around each hole, there is also a single-sided sticky gasket to prevent water from seeping into the holes. If you search hard enough, you might find a post that shows the picture of these gaskets. But I do remember there not being a whole lot of information.
If the OEM spoiler you're purchasing does not come with hardware, you can find them at a hardware store. They're pretty standard-looking nuts and bolts. As for the gaskets, you can go with a thin layer of 3M double-sided tape. I haven't installed mine yet, still waiting to paint it. But back in 2007, when I had my first s2000, I installed an Ebay replica and that's what I used. Worked just fine, no leaks and no rust.
Old Nov 16, 2021 | 12:39 PM
dedonderosa's Avatar
pretty sure they are all discontinued new from Honda now. see if you can get a used one
Old Nov 16, 2021 | 04:22 PM
kalm_traveler's Avatar
You can buy new OEM 25th Anniversary re-releases that come primered and include all the hardware. Some sites still have them in stock.
Old Nov 17, 2021 | 04:35 AM
Chuck S's Avatar
There are two OEM rear spoilers plus the extremely limited CR wing.
In the factory box the OEM spoilers (ducktail and little wing) should include all the parts and the CR wing may include the three supports. For some reason I recall the CR wing needs things inside the trunk to handle downforce, the regular spoilers just bolt on. These, like the front spoiler and side strakes, were dealer-installed options and Honda boxed them with all the parts. (I doubt the CR shipped from Japan with that wing sticking up on the back and am guessing the dealer bolted it on.)
Here's the data sheets for the wing and ducktail:
https://s2000.club/OM/2007_s2000_win...r_aii33383.pdf
https://s2000.club/OM/S2000%20OEM%20spoiler.pdf
Lots of parts that show "In Stock" on line turn out to be discontinued when you try to buy them. There are very nice reproduction "ducktail" spoilers available on Ebay finished in body color which are held on with 3M body tape. There are probably little wing spoilers as well but I never looked. Drilling holes in the trunk lid for these cosmetics is something I'd not personally do.
-- Chuck
Old Nov 17, 2021 | 05:30 AM
It was the wing not the decklid. I had ordered it and after a few days they said they were sold out :/
Thank you for your help!
Old Nov 17, 2021 | 05:32 AM
Thank you everyone for your help! I think I am just going to save and buy a Spoon wing
Old Nov 17, 2021 | 07:40 AM
bunz559's Avatar
Yea, some websites say they have them in stock, but more than likely, they're all out. I ran into a similar issue with OEM front spoilers. Best of luck.
Old Nov 17, 2021 | 10:36 AM
Suzuka_Joe's Avatar
the CR wing is still available from Honda but the other wings including the 20th are no longer available anywhere I can find. I've got the Ap2 "wing" and I love it. If I can find a OEM CR wing used I'll probably buy it to have it
Old Nov 18, 2021 | 03:56 AM
ahh yea I can't help you with the wing, but the more common 'ducktail' 25th Anniversary repro is still in stock - I see ICB has them if you change your mind https://www.icbmotorsport.com/hoacs220andu.html
