Ohlins DFV Installation and Review
Originally Posted by clubmagicdrive' timestamp='1465875234' post='23992641
[quote name='Orjinal' timestamp='1465865266' post='23992548']
Why so much camber in the rears with that wheel/tire setup?
71R's run skinny. I ran -3 all around with my 17x9 +45 and 255/40 combo.
I also run -3 with my 17x10 +50 and 255 combo.
I'm curious how you got -3.8 degrees of camber with 0 toe. Adjustable upper joints?
I also love my Öhlins. Good choice.
[/quote]
Interesting! Compared to what was on before, I feel that they run wide, but that's my opinion. To run 255 square did you do quite a bit of work to the front fenders? I'm looking to run a square 17x9 +45 set-up next year, so I'm looking at my options. I've modified the fronts so tabs are flat, and rolled/relocated the rear tabs.
Rear camber was just stock adjustment and the ride height - nothing special!
I have my fender LIPS rolled and I cut the tabs off up front. I relocated the rear tabs. I would highly recommend cutting the front tabs instead of folding them, even for a mild wheel fitment.
My fender shapes are stock. I have not flared them, even with 17x10 wheels. Plenty of clearance with -3 degrees. My ride height is lower than yours.
I have SPC front upper ball joints. So I can run minimal camber with maximum clearance. My 17x9 and my 17X10 clear my UCA and inside fender just fine at full lock. I don't rub anywhere. 6.x degrees of caster. 0 toe up front. +.17 deg toe per side in back.
B serious, why do you recommend the cutting of the tabs on the front fenders as opposed to folding them inward? My fender roller just pushed them inward and I'll be using 17x9+45 with 245's and I'm hoping I won't have to modify them any further.
It is a little hard to explain but in my expereince rolling fenders it is easy to cause it to look uneven due to the tabs sticking out further that the lip and therefore getting pushed by the roller or more pressure is applied to the spot with the tab pushing it out further making it look more uneven. Of coarse if you take your time and do it right it is not an issue but cutting the tabs down would possibly solve this concern though cutting has it's own risks. I try to avoid cutting anything unless there has been a repair and there is bondo or something that will crack or have other issues. Either way as long as there is nothing for the tire to grab either way is fine.
If your tire ever grabs a hold of that tab, it will turn that portion of the fender inside out.
The tire grabs onto the tab and bends it/twists it so that it faces outboard. Imagine your fender with wings lol. It causes a lot of damage.
I have had this happen (spin/half spin at a track) with a weenie set of 17x7.5 +45 with 225/45 tires and -2.2 deg camber.
It can also happen on driveways or if you get into a situation on the street where the rear steps out and you countersteer.
Or for the tab just above the tire, it can happen on dips in the road.
I cut mine flush with something small and slow like a dremel. Then cover the "scar" with epoxy and undercoating.
