Sponsored by: CARiD
Oil Drain Plug Vavle
Old Feb 5, 2012 | 09:40 AM
deanbayley's Avatar
Default Oil Drain Plug Vavle
Hi all
i am thinking about getting a Oil Drain Valve from JS2K.
what i am wondering though, does this drain valve replace the sump plug or does it locate somewhere else?
If it does not replace the sump plug, then if you have a magnetic sump plug, the fact that you never plan to remove it would mean a build up of deposits?
anyone know?
Cheers
Dean
Old Feb 5, 2012 | 09:50 AM
s2000ellier's Avatar
it replaces the original drain plug
Old Feb 5, 2012 | 10:13 AM
deanbayley's Avatar
ok cool. isnt the drain plug on the sump though and underneath the car?
iv not got my s2000 yet, but i had one before and im sure the sump plug was under the car where they usually are.
so this drain plug from js2k, how do you use it if it is under the car?
sorry for being dumb
Old Feb 5, 2012 | 12:11 PM
The drain is on the side and with the valve install you can reach it from the top of the motor.
I bought my fumoto valve from http://www.quickoildrainvalve.com/ I chose to get the nipple version so I could put a tube on it and have it drain directly into an oil collection pan.
Old Feb 5, 2012 | 12:13 PM
99SH's Avatar
Yes, the oil drain bolt is on the oil pan which is underneath the car. The quickdrain valve is just that, a quicker way to open up the plug (no tools required). If you have an aftermarket intake that removes the large stock air-box, you can access the drain valve from under-hood.
Old Feb 5, 2012 | 12:38 PM
zeroptzero's Avatar
there is a drain procedure video on their website which shows the drain in action. You magnetic drain plug will not be used with this device, there won't be any build up of deposits to worry about as a magnetic drain plug doesn't catch much.
Old Feb 5, 2012 | 01:41 PM
deanbayley's Avatar
Cool. That's all I was worried about. Cheers guys.
So going back to what you say, is it hard to get to if the standard airbox is still in place?
Old Feb 5, 2012 | 02:12 PM
if you have long slender arms you could probably reach it from the passenger side.
Old Feb 5, 2012 | 06:24 PM
JackS's Avatar
I have the std filter with a stabilizer bar and have no trouble reaching the valve from under the hood. Kind of a tight fit for my arm but really no problem.
Old Feb 5, 2012 | 10:50 PM
deanbayley's Avatar
And I take it all of you who have the valve have never had any leaky issues?
