Oil Filter Retainer
Before you give it another thought you should really do a search yourself (in the racing forum) to see if this is really a rampant problem or snake oil, profit making parts. You can probably already guess the answer right?
Derek,
Rod has it right. Just get a large hose clamp to go around the filter and a wire to secure to a nut on the block.
Also, if you use the PCX filters, you shouldn't have an issue of backing off. Iain's was based onhis using a Mobil 1 filter that didn't have the metal/metal that the PCX provides
agreed though...a simple metal hose clap with some safety wired (wired correctly meaning to the right) will be your answer...no need to pay $35 bucks on an oil filter retainer....make it yourself...piece of cake
