over fenders
if i install rear over fenders can i later go back and roll my fender while they are installed?
or would i need to remove the over fender roll and put back on?
would it be best to roll fenders before i even install?
thanks
thanks
I don't think its harder or easier with them installed or not. But If you plan on doing a fender roll, why not do it before?
The roll of the fender will not effect it, I had overfenders installed and also molded to my rear quarter and the fender roller was able to do it with no issue.
just do this:
Cut your back fenders
Roll them and have them spot welded back together
Sand down prime and then paint to stop rusting
Use some rhino liner on the inner fenders to re coat everything and stop rusting inside as well
You dont want to do this after you get the fenders on, it WILL be 10 times harder and you will end up pulling the fenders off and then putting them back on again
Originally Posted by milkman2089,Sep 30 2009, 11:01 AM
anyone have pics of an s2000 with rear overfenders with stock ap1 wheels?
i mainly want them for the look not bigger tires
I am planning on bigger wheels but nothing to the point i have to cut my fenders
I just gotta save up a bit more
anyone got an advans rs? or rgIIs?
if you're installing overfenders without cutting the fender out (not sure why you would come back for a roll later) then you are missing the point of the overfenders entirely, lol
so you want the look of overfenders coupled with the look of wheels and tires that sit far enough inboard that you dont need to mod the existing fenders? ew..
Let me tell you from experience... Roll your fenders first.. OR take a dremmel and cut the rear fenders...
If your rims and tires are as wide as mine, your gonna have to relocate the screw from the bumper to the fender back about an inch or so.
If you decide to cut, sand down and primer.
I've put stock ap2's with these over hangs and it looks stoopid... the whole point of overfenders is to push the rear out more..
I have 18x9.5 rear with 40 offset and 255/35's in the rear...
killerbee_vr6
Oct 11, 2012 02:19 PM
