Sponsored by: CARiD
please help installing K&N intake 2006
Old Jun 4, 2010 | 04:12 PM
markpenske's Avatar
Default please help installing K&N intake 2006
I have a MY 2006. I'm in the process of installing my new K&N intake. The instructions are for all model years & are a bit confusing. I was hoping to find someone with a 2006 that installed a K&N intake that might be able to help me out. A few of the items I'm having trouble with:
- Step 10. Detach (2) vacuum hoses. I do not see these hose as shown in the instructions.
-Step 11 How can I tell if my car is equipped with an air injector pump? I have a 2006. Where is it located
- Step 12, Detach hose from air control vacuum check valve. Where is the check valve.
- Step 18. Install a coolant bypass. Yes or no?
THANKS IN ADVANCE
Old Jun 4, 2010 | 05:20 PM
whiteflash's Avatar
Witha 2006 you don't worry about that. The instructions are for general for all years. So don't worry about it
Old Jun 4, 2010 | 05:28 PM
markpenske's Avatar
So, a 2006 does not have an air injection pump?
Old Jun 4, 2010 | 05:30 PM
Crackerballer's Avatar
^^^ NO.
Old Jun 4, 2010 | 05:47 PM
markpenske's Avatar
so, on a model year 2006 you can skip steps 10 thru 18?
see link
http://images.autoanything.com/images/info...282101&kc=AFFCJ
Old Jun 4, 2010 | 05:49 PM
whiteflash's Avatar
Yes, exactly. As well as any instructions after the install that have to do with those parts.
Old Jun 4, 2010 | 06:06 PM
markpenske's Avatar
Cool, thanks.
Just one other thing. (step #18) I read that some owner suggest NOT using the coolant bypass & re-installing the coriginal oolant lines to their original places. Others say Yes, use the bypass as shown in step #18
Old Jun 4, 2010 | 08:47 PM
whiteflash's Avatar
I can't imagine why you wouldn't. I did on mine....
Old Jun 4, 2010 | 11:12 PM
ans2k's Avatar
Originally Posted by markpenske,Jun 4 2010, 09:06 PM
Cool, thanks.
i did on mine when i had it. i dont see why u wouldn't. if u dont, you would have some tacky setup, with unconnected metal hoses.
Old Jun 5, 2010 | 10:22 AM
Grady's Avatar
You don't have to drill a hole in the intake either for the IAT sensor. Just use the hole that they have already put on the intake. It holds the IAT sensor just fine.
