Possible seat theft deterrent
On the road so I can’t post pics but I added decals to the side door windows in the hope of avoiding a literate thief attacking my car thinking the seats were easy pickings. I was able to procure a set of McGuard bolts from a member here 6 years ago. I found some “McGuard Seat Locks Installed” vinyl decals made to match my Rio Yellow. They are in the inside and are visible despite my tint.
Worked so far.
Worked so far.
What does JIS stand for, and is it better know by another name. First time I've hear of that, and searching McMaster Carr, nothing comes up by that name/term.
A bit more searching on McMaster Carr produced what may be the perfect solution:Metric Stainless Steel Tamper-Resistant Button Head Hex Drive Screws.
Part number 95635A736 in M8 x 1.25 by 30mm (which I believe may be the right size) sells for $11.73 for 10 of them, and the tool is PN 7253A64.
The front bolts and rear bolts are two different sizes. I used one grade 8 button head up front but it is not one of the tamper resistant ones. If you have a good hardware store near by you should be able to get what you want without having to buy 10 at a time.
ROD
ROD
We all know seats can total one of tjese cars, and that Honda prices out each poece of the seat individually. All I was asking is if the cost of just the leather and foam pieces from Honda are outrageously expensive, enough to potentially total a car (or are only the deat frames outrageously expensive).
Yes, you can get seats repaired at an upholstery shop. You can also buy aftermarket performance seats. Insurance typically doesn't consider those options.
I would be careful with those. A button head fastener will have a lower UTS value than a hex head. That means that the head may pop off under tension sooner than the hex head bolt would. I may be wrong though; best to check the strength numbers to verify. You want your seats staying firmly in the car under all conditions (theft and collision).
Right. They can't steal the seats, so they get pissed and slash up the leather and foam, leaving the seat frames in place. Now insurance will want to replace the damaged pieces with new from Honda. If the cost of those parts exceeds a threshold based on cars value, they total it.
Some Ins. tries to get these wheels instead of real Honda S wheels. So what. I'm in my 60's and have over two million miles of over the road experience so I've also had some experience dealing with Ins. co..
https://www.hubcaphaven.com/c/411/ho...eels_rims.html
ROD
