Sponsored by: CARiD
Power steering hose
Old Apr 8, 2021 | 03:02 PM
Bay2k's Avatar
Default Power steering hose
Do anyone what is the part number for this hose from the power steering
Old Apr 8, 2021 | 06:41 PM
R00567's Avatar
Bro - your power steering is electronic hence the acronym EPS in this car - i.e. no fluid or reservoir tank etc.. That line you are point to is a AC line and from the looks of it someone has put a rubber hose around it to prevent things to rub a hole in it.
Old Apr 8, 2021 | 07:07 PM
Bay2k's Avatar
Do you think is necessary to replace it?
Old Apr 9, 2021 | 01:37 AM
flanders's Avatar
If AC is working then it should be good, what you probably need though is to clean that engine bay.
Old Apr 9, 2021 | 05:36 AM
Chuck S's Avatar
The foam covering is necessary -- Honda put the cover on. These are not the OEM clamps but will do.
-- Chuck
Old Apr 9, 2021 | 05:42 AM
Car Analogy's Avatar
Actually, it looks like someone replaced the factory foam insulator with a rubber hose, then added clamps to hold it in place.
They would have had to slice the hose lengthwise to get it on, hence clamps necessary to keep it in place.
Guessing original factory foam was damaged or disintegrated or something.
A very reasonable fix.
Civicbeater
Cars for Sale
Oct 31, 2018 07:31 AM
s2kanonymous
Feb 17, 2016 02:56 PM
