Racelogic questions
Hi everyone,
I installed the RLTC last week and did extensive testing this weekend.
I'm very very happy with the system .. it really does give you extreme confidence in corners because you can floor it everywhere and it simply corrects throttle input to give maximum power given the traction.
And ... at anything more than 15%, the car still goes slightly sideways whenever provoked.
I managed to do constant, controlled drifts around a roundabout last night .. always with full throttle and counter-steering. IMO the strange noise is the only let-down
Anyway onto the questions ...
1. What is the best RPM for the launch control? I have set it to 6,500 rpm.. but my buddy Trip intervened (again
) .. he said that although this would give a good launch, it will be very hard on the gearbox and diff ...
Thoughts?
2. Has anyone fitted the digital adjuster in the radio door? I really want it somewhere easily accessible .. and this is the best place I can think of.
I've actually already got an old-style black one which i intend to cut and fit the digital adjuster into. i later plan on spraying it silver to mock the new-style radio door. I'm just wondering .. has anyone done this before?
Thanks
) .. he said that although this would give a good launch, it will be very hard on the gearbox and diff ... Thoughts?
Thanks
strange i got no replies, but here's an update anyway ..
i installed the digital adjuster in an AP1 radio door (sprayed silver)
Quite happy with the result. There are only two minor things that bother me:
1. When I cut up the hole in the door, I cut it "square" .. I later realised that i should have made the corners rounded :s
2. The door does not open freely .. for some reason it "hits" slightly from the top, so you have to pull it to start opening .. and the cables do hold it back slightly ..
But then again, I dont open up the door much so no worries
