Sponsored by: CARiD
Rear bumpsteer kit not needed for AP2? front?
Old May 27, 2009 | 09:49 PM
ASpec818's Avatar
Default Rear bumpsteer kit not needed for AP2? front?
I'm experiencing bumpsteer while taking turns at speed. The steering wheel kinda pops out in another direction if I hit a bump through the turn. I heard a rear bumpsteer kit is not needed for an AP2, so will a front kit alleviate this?
Alignment has been done and is within specs. I'm driving an 04 lowered about 1.5" on GC coilovers w/ oem shocks.
Old May 28, 2009 | 05:25 AM
Orpheus's Avatar
Dunno the answer. But just FYI I am lowered same amount and my cat doesn't do that. You might have other issues. I also have a highly modified AE86 as well. And that car does what you observe very heavily. But through many forum suggestions and discussions, I have come to the conclusion that what I thought was bumpsteer was just steering input from the fully-metallic suspension (no bushings at all.) But that's probably not your situation, as I doubt you went that far with the mods. So, again, my car is lowered almost as much (HKS coilovers, but shouldn't matter), and there is no significant steering wheel tugging at all going over bumps.
Old May 28, 2009 | 06:00 AM
DER MotorSports's Avatar
Just to clarify, Bump Steer can only occur at the front of autos (unless they have 4 wheel steering); Roll Steer occurs at the rear. My perspective is it's easy to check for either; why not set them up and run the numbers. However, 37,5mm lowering would definitely get you near the neighbourhood of these maladies.
May I further suggest that you may be hitting the bumpstops which effectively sends your rates to infinity. This will cause all manner of havoc with the handling making it difficult to diagnose
Miata_Nut
Nov 2, 2018 06:52 AM
veilsideLGD
Jun 12, 2011 08:45 PM
S2S
Aug 19, 2008 04:29 PM
jyeung528
Apr 18, 2007 08:15 AM
