Sponsored by: CARiD
rear camber kit
Old May 3, 2009 | 03:25 PM
jonnys2k01's Avatar
Default rear camber kit
what are you guys using to correct this issue when lowered?
the whole control arms are a bit to expensive for me!
Old May 3, 2009 | 03:56 PM
AP1rulz's Avatar
no need for extra parts... u can adjust camber with stock components!
If camber is still incorrect, hold adjusting bolt on control arm and loosen self-locking nut. Turn adjusting bolt until camber is correct. See Fig. 10 . After adjusting, tighten self-locking nut while holding adjusting bolt.
Old May 3, 2009 | 03:59 PM
jonnys2k01's Avatar
its already adjusted to the max.. which isnt enough.. hents teh reason i posted this..
Old May 3, 2009 | 05:46 PM
K1LL3R 1NS1D3's Avatar
i have the same problem im maxed out and the best i could get was -2.4 degrees in the back. is there a way to get passed that setting with the stock concentric bolts?
Old May 4, 2009 | 04:13 AM
RichV's Avatar
^I had a similar problem. I bought the adjustable ball joints and that gave me plenty of adjustablility. You can put them on the front or rear.
Old May 4, 2009 | 08:55 AM
DFWs2k's Avatar
where'd you buy the adjustable ball joints from?
Old May 4, 2009 | 11:26 AM
jonnys2k01's Avatar
how releiable are they?? can they withstand track days???
Old May 4, 2009 | 09:16 PM
shotgun2224's Avatar
i would also like to know how to get more camber so bump
Old May 6, 2009 | 04:19 PM
DocB04's Avatar
get the ct engineering or spc adjustable upper ball joints.
i don't know how they'll hold up to track days but they'll give you -3 degrees more camber...
Old May 6, 2009 | 04:48 PM
RichV's Avatar
^thanks. i got the spc ones. They work great. Just do a google search and you will find them. I can't remember where I got them from. They are torqued to 220ft/lbs. Track driving won't budge these things. My installer (a big guy, said he had to strain big time to get to 220 ft/lbs!)
