Sponsored by: CARiD
Rear fender flare and offset !
Old Oct 31, 2014 | 02:23 AM
Tboy's Avatar
Default Rear fender flare and offset !
Hi guys
Just want to ask if anyone ever had the circuit garage rear over fender on their car before ? I believe it will gives about 70-75mm more guard clearance at the rear so here is my question : atm my rear oem fenders ( rolled ) can handle the 18x11.5 +57 with 285/35 , and if i use the circuit rear fender flare which gives me about 70mm more room clearance so wat offset for the new wheels should i run to get more wheel lips this time ( as im a fan of deep wheels lol ) ? Can i run 18x11.5 +0 ?? Btw planning to order a set of ccw's custom wheels this time so i can have whatever width and offset aswell !
And also does anyone know how much for the circuit garage rear fender gna cost ?
Thanks in advance guys help me out !
Old Oct 31, 2014 | 03:14 AM
DaGou's Avatar
good question? Are you running those overfenders just for looks? Most people use overfenders as a means to an end, they want to run wider tires in the rear. Why does anyone want 3 more inches on each side when you are already rolled and running 18X11.5? It has to be just for looks for there is no function there. I am not a hater, just trying to see where you are coming from. Kind of a cheap wide body thing?
Old Oct 31, 2014 | 04:29 AM
Tboy's Avatar
Yea i know wat u mean about running wider tyres on over fender but as i said i just wana know if i can running those width and offset with the +70mm wider fender ? To see if its sit flush with the guard or no !! And hell no they not a cheap wide body things at all , ppl said they worth $700 just for the rear fender flare tho
http://www.circuit-garage.com/2014/0...st_18.html?m=1
ipeefreely
Mar 16, 2017 08:51 PM
Hershey
May 24, 2013 07:37 PM
\\s2kris//
Dec 9, 2010 07:56 AM
MAmorn
Mar 1, 2007 05:51 PM
spoiled@21
Oct 25, 2005 11:55 AM
