Rear/Fully body diffusers.
I installed a rear diffuser on my car the other day, and its probably all mental, but I feel like the car is actually faster now. It seems to require less throttle at highway speed as well. It maybe in my head, I just wonder if adding a diffuser makes this big of a difference and if anyone else had noticed the same thing? I mostly installed it for theoretical benefits and looks but it seems to have a positive effect?!
Thoughts?
Thoughts?
Originally Posted by Gigdy,Jan 21 2011, 07:15 AM
Id bet unless the entire bottom of your car is flat it is just adding drag.
unless the entire bottom of your car is coverd up, its all in your head pal. but hey whatever works right?
what diffuser did you end up installing? just curious?
Most of the underside of the car is flat, except the rear 1/3. Covering as much as possible would have positive benefits. Take the exhaust for example, it probably hangs lower than anything else, if you held a piece of 2" pipe out of the window of your car at 70mph if would give you an idea of how much drag a bit of exhaust hanging down can create.
Even if it doesnt do much, it looks MUCH better. You cant see the exhaust and rear subframe when you're behind the car. Looks more finished.
