rear toe link removal
ok so when I replaced my rear knuckle I noticed that the rear toe link ball joint was bad. I popped the ball joint already. how does the bolt come out on the drivers side? I can't seem to get it off where it is bolted into the frame with a bushing. is it just a PITA to remove? mine maybe stuck on. I'm going to PB blast it tonight. any info will help out a ton thanks.
Hopefully just PB will be enough for you, but above is worst case. Hose it down with PB, and remember to tap it with a hammer several times. This helps work the penetrant into the seize. I'd go back a couple more times and do it, and hopefully in the end you can just drive it out with a heavy hammer.
I just did this on wife's Lexus RX. I went through like 5 blades. I'll know to get The Torch blades next time.
Another Top Tip, anti-seize the new bolt so this doesn't happen again, and remove the other one and lube it up too, while you still can.
Good tip on the anti seize, I do that as well.
miataroadster
Oct 15, 2009 06:21 AM
