Recommended height for PSS9
I got a set of used Pss9 and I don't have the manual. I wanted to know the recommended height from Bilstein. Any info will be greatly appreciated.
Thanks Huy |
i got it, hope you still need it
measured from top edge of spring seat down to center of bottom moutning screw (to clarify their directions, bottom of spring seat means where the spring meets the first of the two height locks) front 310-345mm rear 205-215 mm also it says "ride height of tested vehicle: 95mm" but i do not know where they are measuring that from, if you figure it out let me know. |
FYI
Rear 205 = the lowest you can go so the rear would be around 1 loose finger gap to 2 finger gaps (215) Erik |
I have the rears set almost to the lowest (205mm) and the front about midway. After a few weeks, I have about 1 finger tight in the front and 2 finger tight gap in the rear.
Good write up btw.... https://www.s2ki.com/forums/index.ph...c=258639&st=50 |
thats weird. i'm at 213-215 and i've got 1.5 finger in the back. lol
