Sponsored by: CARiD
Recommended height for PSS9
Old May 20, 2008 | 03:07 PM
S2k_RN's Avatar
Default Recommended height for PSS9
I got a set of used Pss9 and I don't have the manual. I wanted to know the recommended height from Bilstein. Any info will be greatly appreciated.
Thanks
Huy
Old May 23, 2008 | 02:40 AM
terahertz's Avatar
i got it, hope you still need it
measured from top edge of spring seat down to center of bottom moutning screw (to clarify their directions, bottom of spring seat means where the spring meets the first of the two height locks)
front
310-345mm
rear
205-215 mm
also it says "ride height of tested vehicle: 95mm" but i do not know where they are measuring that from, if you figure it out let me know.
Old May 23, 2008 | 02:57 AM
3r1k's Avatar
FYI
Rear 205 = the lowest you can go so the rear would be around 1 loose finger gap to 2 finger gaps (215)
Erik
Old May 23, 2008 | 01:16 PM
S2K23's Avatar
I have the rears set almost to the lowest (205mm) and the front about midway. After a few weeks, I have about 1 finger tight in the front and 2 finger tight gap in the rear.
Good write up btw....
https://www.s2ki.com/forums/index.ph...c=258639&st=50
Old May 23, 2008 | 10:45 PM
terahertz's Avatar
thats weird. i'm at 213-215 and i've got 1.5 finger in the back. lol
decepticondc5
Dec 25, 2016 01:49 AM
Zygrene
Apr 2, 2015 12:05 PM
BobKennedy
Feb 27, 2013 02:48 AM
stwokayyy
Nov 26, 2011 07:53 AM
pikkashoe
Jun 20, 2006 01:30 PM
