Sponsored by: CARiD
removing airbox lid for winter
Old Jan 2, 2012 | 10:14 PM
trAP2's Avatar
Default removing airbox lid for winter
I know its better just to keep the airbox lid on because of heatsoak. I did the airbox mod where i blocked the resonator and cut the wall. that made the box flow a little better and sound a little louder but it doesnt compare how good it sounds without the lid on at all. i was wondering if it would be okay to run without the lid on just for the winter time while its cold out. It wont suffer from heat soak as much. What do you guys think? Any drawbacks?
Old Jan 2, 2012 | 10:19 PM
ans2k's Avatar
ehhh, your right heat soak wont be that bad. well depends how cold it is outside. i think you will be fine. if you are just doing it for the sound then, thats all good.
Old Jan 2, 2012 | 10:43 PM
skkppy's Avatar
Old Jan 2, 2012 | 11:21 PM
trAP2's Avatar
Originally Posted by skkppy
Old Jan 3, 2012 | 09:38 AM
Harry Dunn's Avatar
Im running mine with it off this winter. I have not noticed much difference at all from when I ran with it on.
Old Jan 3, 2012 | 04:54 PM
liquid_helix136's Avatar
I can sell you a K&N intake which sounds like the no airbox lid mod on crack.. plus an entire 75 shot kit of nitrous which will definitely make you feel a difference if your interested.
Otherwise I would just try it and see if you notice a difference, particularly in throttle response and low rpm pick up (bogging)
Old Jan 3, 2012 | 05:20 PM
Mark355's Avatar
Originally Posted by skkppy' timestamp='1325576591' post='21280515
[quote name='trAP2' timestamp='1325574846' post='21280460']
[/quote]
Old Jan 4, 2012 | 11:09 AM
mattstryfe's Avatar
Heat soak happens a couple of ways.
1. The actual box gets heated up from the intense heat generated from the engine itself. This is the reason why people install heat shields in between the stock box and the engine. This helps tremendously. I have done it, am doing it, and am altering one I made myself to make it even better. I don't have an IR temp gauge but I can tell you after the car has been running - the stock box (engine side) is luke warm compared to not being able to even touch it.
2. Engine bay air is obviously more hot than outside air. If you remove the top of your box you are still not increasing "cold" air into the intake itself. More air is not the problem, the temperature of the air is what you are going for. Stock, the air comes from the area right infront of the radiator. There are small vents cut into the plastic allowing air to come up infront of the radiator and into the stock box funnel. If you open the box up you are basically negating any chance of the cold air that would come in from the front of your car.
nawmeen?
Hope this helps.
--Matt
Old Jan 5, 2012 | 03:52 PM
Saki GT's Avatar
:wave2:
I took off my airbox lid when I first got the car and it hasn't been on since. never had any issues, never had any trouble keeping up with other S2000s on group drives, and I love the intake growl.
Old Jan 5, 2012 | 04:30 PM
trAP2's Avatar
nawmeen?
Hope this helps.
--Matt
pic of heat shild on stock airbox? i am thinking about trying this
