Sponsored by: CARiD
Replacement seals and brackets
Old Jun 1, 2014 | 04:46 AM
zippity's Avatar
Default Replacement seals and brackets
Where would you go and what kind of replacements would you buy to replace your existing seals. Also, if you would need brackets for an RSG mugen rep, where would you pick them up? All help is appreciated.
Old Jun 2, 2014 | 04:10 AM
zippity's Avatar
What adhesive do I use in order to fix seals that are starting to peel off and coming loose? Thx!
Old Jun 3, 2014 | 03:20 AM
zippity's Avatar
This is an easy question for the s2ki community
Old Jun 3, 2014 | 06:19 AM
jst2878's Avatar
Oem hardtop hardware is the best. Not sure about the seals, but I'm sure GE clear silicone can work. Just tape the seals once you silicone and let dry for a day
Old Jun 3, 2014 | 06:42 AM
zippity's Avatar
OEM seals work for a Mugen top? And thanks for the silicone advice!
Old Jun 3, 2014 | 09:59 AM
CoolGuy094's Avatar
OEM seals do work for a Mugen top. OEM seals come installed on real Mugen tops.
Old Jun 4, 2014 | 09:12 AM
StormTroopinAP2's Avatar
You can order the brackets and seals from RSG.
OEM hardware and seals will need to be ordered from a Honda dealer.
Forbidden USA makes replica OEM hardware but I believe there's a wait time for them right now. You can also order brackets and seals from Forbidden USA.
Old Jun 4, 2014 | 04:26 PM
Thateguhate's Avatar
RSG Themselves.. I went and bought a bunch of shit from pepboys that never worked well and eventually sucked it up and ordered a new set from RSG... I installed it right the this time though and everything has been fine..
3rd time is a charm I guess.
Old Jun 12, 2014 | 03:36 AM
zippity's Avatar
What do you mean you installed them right this time? I notice there is a little wiggle room of where the seals exactly adhere to the hardtop...It seems a little too inside and you will have a gap with the windows...a little too far outside and the window will hit the seal. How did you know where is best? Thanks!
Old Jun 12, 2014 | 08:55 AM
you want the window pressed firmly against the seal when the door is closed, otherwise you will get wind noise
willyummies_
Jul 3, 2017 04:37 PM
SuperSaiyan
Feb 8, 2012 03:40 PM
etang789
Apr 1, 2011 03:14 AM
dan_uk
Jan 11, 2011 11:33 AM
S2000RO_JA
May 24, 2005 01:08 AM
