Replacement seat options in 2024
Would like to replace both seats in a 2008. Not tracking but would like something that sits lower than stock. Did some searching, are Recaro Pole Positions the easiest replacement seat option?
Recaro PPs with PCI sliders are the BEST replacement option. If I had black interior I'd get ABE poles in black leather....would look like a nearly factory option and would seat a slightly wider range of asses.
Is there a preferred Recaro reseller for the S2k community? I'm in the DC area.
I used a guy on FB - Will Long. He's a distributor and he got me the hookup on my PPs and PCI sliders. Other than that I don't know anyone specifically, but I can vouch for Will.
.4" wider at the bottom seat cushion according to Recaro's specs, so just a touch wider at the hip. Other dimensions are the same from what I can find online.
https://www.recaro-automotive.com/us...osition-abe/3d
Has anyone come up with a "solution" for the passenger weight sensor in 06+? Did some people move the OEM seat rails over to the PPs? I rememeber reading something like this a while ago. In the 06+ there is a passenger weight sensor you need to factor in that will throw an SRS light if you just remove the seat and use an aftermarket rail. I recently purchased some ABE PPs for my miata from maar-shop.com. They were the cheapest I found and are straight from Germany. Not sure how they compare $ wise to Kyle's contact.
