Which resonator size?
I have the HKS Hi-Power dual which I think is 60mm. I think I might have the HKS resonator rattle problem because there is a rattle sometimes coming from right where the resonator is.
I was thinking about maybe just replacing it with the Vibrant Performance Ultra Quiet Resonator and want to know if the 2.25 inch or 2.5 inch would be better for the HKS Hi-Power 60mm.
I like to keep exhaust diameter as constant as possible to keep flow velocity constant which I've been lead to believe is beneficial. I avoid abrupt changes. 2.5" is 63.5mm. 2.25" is 57mm. What's your cat diameter?
-- Chuck
-- Chuck
It might not even be the resonator rattling. It just sounds like it is coming from that location. If it is I will probably expand the HKS pipe a few millimeters to fit the 2.5 inch and get exhaust clamps to clamp the new resonator on or maybe have it TIG welded. Do you think exhaust clamps will be fine instead of TIG welding it on?
