Sponsored by: CARiD
S2000 Clutch Replacement
Old Mar 5, 2015 | 01:14 PM
Demdere's Avatar
Default S2000 Clutch Replacement
Ok, so I know there have been write ups on this combo before, and trust me I have read all of them. Tho I can't seem to find a parts list of everything you *need* to replace. (by need I also mean what is worth replacing with the tranny out)
So I have read that OEM clutch with the ACT HD PP works well, but I wonder whether that works with the ACT Prolite Flywheel #600250?
Correct me if I am wrong, but here is what I plan on buying from this diagram: http://www.hondaautomotiveparts.com/...atcgry5=CLUTCH
22200-PCX-055 (Clutch)
91006-PCX-008 (Pilot Bearing)
Do I need any of the bolts or washers?
Then I also plan on getting these:
http://www.summitracing.com/parts/acl-h021/overview/ (ACT HD PP)
http://www.tunersports.com/act-proli...350_p7182.html (ACT Prolite Flywheel)
Anywhoo, any input from someone who knows what they are talking about would be awesome.
Thanks, Alastair
Old Mar 5, 2015 | 01:29 PM
Memo6453's Avatar
Friction disk 22200-pcx-055
Throw out bearing 22810-pcy-003
And I also grabbed a TO bearing guide 21103-pcy-003
I also went with AP1 flywheel. I hear 12-14lbs is the sweet spot.
Also, Moddiction or MAPerformance have the ACT Pp for cheaper.
Old Mar 5, 2015 | 09:59 PM
Demdere's Avatar
Is the throw out bearing a pilot bearing? and I am driving an AP1, so I kinda wanna go lighter
Old Mar 5, 2015 | 10:17 PM
Demdere's Avatar
or do I not need a pilot bearing?
I am just trying to put together a complete parts list :/
Old Mar 6, 2015 | 06:53 AM
Memo6453's Avatar
You'll need pilot and a throw out bearing. 2 different things
Old Mar 6, 2015 | 09:03 AM
Demdere's Avatar
Ok so.
Pilot bearing
Throwout bearing
Clutch plate
Pressure plate
Flywheel
Is there anything else i am forgetting? - you mentioned a bearing guide?
Old Mar 6, 2015 | 09:30 AM
wadzii's Avatar
Banned
replace the guide tube, those things get galled by the to bearing and will cause the bearing to hang up when you start to release the pedal.. makes things really wonky.
Old Mar 6, 2015 | 12:06 PM
Memo6453's Avatar
Originally Posted by Demdere
Ok so.
Pilot bearing
Throwout bearing
Clutch plate
Pressure plate
Flywheel
Yes I gave the part# as well...
GookieMonster
Nov 8, 2012 11:49 AM
lreyn003
Nov 18, 2011 08:31 PM
bjonesz28
Jul 30, 2008 05:33 PM
