Sponsored by: CARiD
s2000 Side badges
Old May 30, 2008 | 09:03 AM
SupeR_DavE's Avatar
Default s2000 Side badges
hello,I am needing alittle info to make sure I dont mess anything up. I just got the Black CR "s2000" fender badges. My question is, what is the best way to do this install? best way to remove the current "s2000" badges without messing up my paint
Old May 30, 2008 | 09:30 AM
6speedftw's Avatar
i used dental floss to removed the emblems.
Old May 30, 2008 | 09:37 AM
chillout18's Avatar
keep the glue nice and warm by using a hairdryer...then use dental floss to try seperating the emblems from the fender....when thats all set the fun part begins because now you have to get the glue off. try goo gone, bur and tar remover, or rubbing alcohol beasically see what works best for you but be patient because its gonna take a little while to get it all off
Old May 30, 2008 | 09:46 AM
SupeR_DavE's Avatar
thanks guys!
Old May 30, 2008 | 01:43 PM
jshimer23's Avatar
I used a heat gun that quickly softened up the glue to the point where the the fishing line I used cut through like butter. Then yes, rubbing the glue off the fenter is a pain but not hard. I used goo gone and kept the fender warm with the heat gun. If you use a heat gun, you don't need to "over" heat the glue. Just enough to make is soft.
Old May 30, 2008 | 01:48 PM
Filthy Beast's Avatar
I agree with all above, but before you start block off the emblem that you are taking off with masking tape. That way you will get your new
one back in the same sopt.
Old May 30, 2008 | 01:51 PM
HS2K007's Avatar
yes put a piece on top and botttom of the emblem. mark with a pencil were s2000 starts and stops. the cr emblem is probablly longer, so the sides may not be necessary.
Old May 30, 2008 | 02:04 PM
sillyboybmxer's Avatar
get 3m adhesive remover,...thats what i used when i worked as a detailer and had to remove them,...let it soak on and it will wipe off with one sweep of the hand and rag
Old May 30, 2008 | 03:27 PM
shotiable's Avatar
goo gone and a lot of patience. my friends helped me remove mine but i dont know why it took so many hours to do so >.<
Old May 30, 2008 | 05:49 PM
SlideWayS2k's Avatar
KNOCK THE BADGE OFF WITH A BRICK OR CINDERBLOCK THEN DUCK TAPE NEW BADGE ON. INSTALL IS QUICK AND EASY AND YOU'LL DEF GET SOME PEOPLE TURNIN HEADS... HAHA
