s2k POWER & SUSPENSION IM NEW!
Originally Posted by motoray69,Jan 13 2008, 10:21 PM
did your intake mods make a nice difference? and whats with the breathers. pics? O forgot to ask with the o2 sensor on the cat doesnt putting the test pipe screw with the ecu readings
The way I have come to understand it, there is some tuning involved with these intakes and though i'm sure there is a couple unique ad expensive intakes on the market that may provide the right "tune," the factory box is properly tuned to the car. Besides cold air, there is some scavenging or a tune that the intake provides to create max force to the engine, some type of filter restriction, usually revolving around a housing or cover of some type creates this, others like the AEM have attempted it through a duel tube chamber design. I have my doubts about open filtered intakes. Plus if they are still in the engine bay they are sucking in hot air or are at the risk of sucking water or debris if relocated.
Sorry no pics, I realize this would be helpful, so i'll explain best I can. The breather allow no chance of oil getting into the intake charge via the pvc and front vent. You can do this with a catch can and I did at first, but then discovered that I gained even more power by eliminating the catch can and just plugging the two intake manifold locations where the pvc and front breather once were hooked up. Its not smog legal fyi. It creates more intake vacuum and its also free of oil vapor, which is a good thing taken to the next level. Its just like what the old pre emissions v8's had for a set up. Damn! I'm giving away all my secrets, oh well.
No problem with the 02 bung interfering, you need the extended bung for the fix so as not to trip it. Ebay -$10
hmmm i would like to hear more about ur intake mods. Whats with the extended bung? that keeps it from freaking out? O howcome i dont see anyone with cams from what ive been seeing they can crank out some nice power. O did u have a dyno shop do ur VAFC?
Thats right, it keeps the gases further away from the sensor so it is only reading partially what your actually putting out, it just is a hollow bolt, with threads on both ends and can be had on ebay right now for about $10.
I have a frog harness so installation is super easy, no cutting required which will prove to be worth every penny of that $150, especially if you have a problem and can eliminate the 50 spliced wires as the source right of the bat. I took it to have it tuned but the dyno wasn't able to read my AFR's properly and so he wasn't able to tune it, so I had a second bung welded in my test pipe next to the other one and purchased a AEM wide band monitor and learned how to tune via VAFC myself. This is way better anyway. You can keep you car running safer and maximize its power. Just because you tune it at the dyno at 50% humidity and 70%temp at 13.3afr doesn't mean on a 40% day the car won't be now running at 13.6afr because it likely will, and you will need some on board means of seeing this and then adjusting for it. My afr's fluctuate with the weather conditions and this is normal. If you like getting the most from your car you will be at a point where some days your running to lean for safe conditions or to rich to maximize your investment in power modifications. Get a wide band and learn to tune yourself is highly recommended from me.
Originally Posted by motoray69,Jan 14 2008, 11:17 AM
how much earlier can u make the v-tec kick in and is it bad for the motor?
Save your money on all that garbage and get gears.
It's the only thing that'll be for go and not just for show.
Do you want bling or performance.
You'll lose more performance with 18s than you'll gain with all the mickey mouse mods combined.
