selfmade ducktail spoiler
Here are some pictures of my selfmade ducktail spoiler. Based on the OEM spoiler. I make it with pu foam and shape it to the fundamental form. Then I used fiberglas putty fill all holes and for shaping I use polyster putty. For the stability I used a 120g fiberglas fabric with epoxy resin.
All the foam does is provide the shape for the glass, and hold it in place while it cures. All it does now is maybe add some sound deadening so trunk sounds more solid when you close it.
Yes thats correct. When you like you also can "wash out" the foam with acetone. You don't need it when you have the form. The only problem is the different expansion from the fiberglas and the metal trunk. It's possible to get stress cracks when the sun heat the trunk up. I have make this experience on similar projects. But I very lucky with the trunk until now
This is also the reason why I wont to build a mould and make a full composite trunk lid.
