Sponsored by: CARiD
Shaved / Sanded OEM intake manifold
Old May 6, 2012 | 08:58 PM
S2K-F8's Avatar
Default Shaved / Sanded OEM intake manifold
Just thought I would share my progress. I picked up a used OEM intake manifold, sent it to Fullblown to have it ported to match their 74mm throttle body. When I got it back I decided that I wanted to have it powdercoated in a semi-gloss black. In prep for powdercoating I decided to sand all the casting marks off (mostly just the surfaces that are visible when the IM is installed).
I have never taken on a project like this. I bought a 30gallon air compressor, a few air tools, many sanding disks, etc. Most of the work was done with a 90 degree die grinder, 4" grinder, and a dremel.
All vacuum ports were shaved and filled (except brake booster port)
Secondary air injection port shaved and filled
Water ports shaved and filled
Fairly smooth
New home for the AIT sensor
Almost ready for powdercoating! Will post more pics when I get it back.
Scott-
Old May 7, 2012 | 07:35 AM
Gernby's Avatar
Former Sponsor
Looks nice, but I don't understand why you didn't just port match the TB flange yourself, since you already have the tools to make quick work of it. If I was going to send it off anywhere to have something done to it, I would have had it extrude honed on the inside.
Old May 7, 2012 | 08:17 AM
S2K-F8's Avatar
I didn't feel comfortable doing the TB opening myself at the time. I knew that there was going to be some welding involved when opening the port up that large. Actually I didn't buy my compressor / air tools until after the IM came back from Fullblown.
At this point if I were to do it again, I would def do the TB opening myself!
Scott-
Old May 7, 2012 | 08:47 AM
AngryTurtle's Avatar
Dont paint it! It looks great.
Old May 7, 2012 | 09:19 AM
siik_ap2's Avatar
what are you doing with the coolant port next to cyl. 1 runner and the coolant port on the t-stat housing..
Old May 7, 2012 | 12:22 PM
S2K-F8's Avatar
Are you talking about the port right by the bleeder valve? If so, I have tapped it to accept a M6 bolt and will plug it with a bolt.
Old May 7, 2012 | 01:54 PM
S~Factor's Avatar
This looks great!
When you say 'filled', what do you fill the holes and gaps with?
Old May 7, 2012 | 02:02 PM
S2K-F8's Avatar
Originally Posted by S~Factor
This looks great!
I took it to a local welding shop that does a lot of aluminum welding. They filled in all the holes for me. Cost was $50.
Old May 7, 2012 | 03:42 PM
Moddiction's Avatar
Former Sponsor
Gonns look sweet! How big were they able to bore out the intake manifold?
Old May 7, 2012 | 04:01 PM
S2K-F8's Avatar
Thanks Ryan! Fullblown matched it up to their 74mm throttle body
