Sponsored by: CARiD
Side marker lights socket
Old May 13, 2025 | 05:23 PM
randomwalk101's Avatar
Default Side marker lights socket
Anyone know where I can purchase a pair of light socket for the S2000 side marker? Thanks
Old May 13, 2025 | 06:46 PM
spider2k's Avatar
Active Streak: 30 Days
Saw plenty via Google
34304-SH3-A01
Old May 14, 2025 | 01:24 PM
Car Analogy's Avatar
The entire housing has to be replaced. Normal failure mode is the plastic spring that holds it in place gets old, brittle. Which is fine until bulb burbs out, and flexing that plastic to remove housing to change bulbs causes it to flex beyond its now brittle ability, and it breaks.
The plastic spring is simply part of the housing molded base. A large C shape, that acts as a spring.
My solution wasto replace incandescent bulbs with LED. If bulb doesn't burn out, no reason to need to remove housing, no need to break it. Last virtually forever.
I went with clear lens, CR style housing. So used amber LED bulbs. No issues with flash rate, etc.
falcone
Jul 21, 2006 07:00 AM
nastinupe1
Oct 15, 2002 12:49 PM
