skunk 2 or other throttle bodies.
ok so if i got a throttle body, a spacer, and broed everything to match the TB size, would i gain power or not? i am honestly trying to do everything i can before i put my car on the dyno, that way i can get everything tuned right all at once. the car WILL be tuned with everything on it
Originally Posted by TwinTurbo540,Mar 13 2008, 01:36 PM
Yes but in a cold climet some times there is iceing of the throttle plate to worrie about. plus keeping the tb cool only matters so much when the intake manifold runs coolent through it as well. The reality of it is the air is heated beafor it hits the combustion chamber to be burned any way. And last is the fuel will not come out of the injector as a perfict spray/ mist it will be more likly to clump together as a drop or drops Thats why carborated cars ran like crap till they were heated up. Even the s2000, if you just start it and drive it will bog all the way up to 6k no talking about it locking you out of VTEC due to the temp. Thats the ecu..... Just some thing to considder.
bottom line is... if you want to spend the money to RISK gaining some power.... then do it!!!.. I say it will add power.... but I WOULD port match the manifold not just the spacer.. also.. If you havnt done every other conceivable mod BEFORE this... I would not recommend it....
well i have a CAI and an exhaust and high flow cats. cats are about to be a test pipe. and i mean a helix throttle body spacer not a spacer that smooths the size transition or anything. and i would port match everything
if you have a tb of say 70mm and the inlet was machined to the same size (i don't think the inlet can be machined above 68mm as it will effect bolt holes), arguably, it may flow better.
however, there seams to be a lot of talk that due to the increased volume, the stock ecu would struggle to correctly idle the car and further to that, it might not even start.
you said you're getting non-oe management so amendments can be made to make the most of the mods, keep us updated
Originally Posted by TwinTurbo540,Mar 13 2008, 01:21 PM
What if i did not port it but i used a tapered spacer? I felt a decent gain but no dyno to see what kind of gain.....
yeh it will be a while before i do get it port matched and the tb and the helix and get it tuned. i actually wasnt planning on using a ems, just getting it profesionally tuned at the dyno. i am looking into a vafc2 or a e-manage though since thta might help even more
