Skunk2 Springs & Bump Stops
Originally Posted by s2k dre,May 13 2009, 10:25 AM
I cut mine in half!
Bump stop does not affect height. It's simply there to prevent the shock from completely bottoming out when you hit a bump. Cutting the bump stop when lowering a car on factory shock just gives you a little more shock travel to compensate for the shorter spring length.
I did mine in the reverse order, so my rear end is about 1/4" higher then the front. I like it much better.
