Sponsored by: CARiD
Sleeved cylinders pros cons.
Old Sep 13, 2013 | 06:30 AM
Bliss's Avatar
Default Sleeved cylinders pros cons.
http://dsportmag.com/browse/tech/pump-up-the-volume
I'm looking for information regarding the pros and cons of sleeving the F20c.
Any advice from you engine builders welcome. Thanks!
Old Sep 13, 2013 | 10:21 AM
herecomesboost's Avatar
Greater selection of pistons (and bore sizes)/stronger
What numbers are you shooting for?
Old Sep 13, 2013 | 11:39 AM
S2K_Vtec's Avatar
Cons: EXPENSIVE Pros: Strong What are you planning on doing? All motor? Boost? Nitrous? The F20 FRM blocks are pretty strong to start.
Old Sep 13, 2013 | 12:50 PM
s2klariat's Avatar
That article is more so regarding a large bore build F20. There are plenty of smaller bore sleeves to be had and there are guys running 1000+ horsepower on built F20/F22's (Look up Carey Bales s2000). Honestly, if you are wanting 400-500 horsepower, leave the engine stock. They stock block can handle a beating (Look up Realstreet's s2000). All depends on what your goals are. If you want a big bore, then the article pretty much gives you the cons, ie less surface space for the head gasket and so on. For an N/A build, big bore could probably be worth it since you're trying to squeeze every ounce of power/torque you can get. But honestly, I don't think the cost is worth it.
Old Sep 13, 2013 | 02:12 PM
Bliss's Avatar
Just gathering as much info as I can before doing this. I would not go max bore need room for next build. Taking baby steps first NA then I may go with hidden nitrous system no drilled intake/direct porting max 75 shot but will keep as small as I can. This car is a daily driver. Shooting for solid 300 hp perfer NA but if I am unable to get the 300 then add nitrous as needed.
Old Sep 13, 2013 | 02:13 PM
Bliss's Avatar
oh thanks by the way Trying NA With solid +300 hp.
Old Sep 15, 2013 | 08:36 AM
Moddiction's Avatar
Former Sponsor
NA 300whp won't happen unless you get huge stroker. 2.7 with itbs and full breather mods with a tune and you should be around there.
Old Sep 18, 2013 | 07:46 AM
S2K_Vtec's Avatar
Check out the f24 build. This is the direction I am going, plus a 100 shot of spray
Stevens2000ap1
Mar 8, 2025 07:25 AM
BalladeSports
245
Nov 30, 2020 01:52 AM
ZwnC
Sep 22, 2011 10:46 PM
Yels2000
Sep 19, 2007 06:36 PM
Shaun@SG
Aug 14, 2005 08:04 AM
