Sponsored by: CARiD
Soft top question
Old Jun 15, 2018 | 12:32 PM
devn's Avatar
Default Soft top question
On my s2k I have a couple holes in my OEM soft top from the previous owner. would I be able to buy a replacement soft top with a plastic back window and replace the back window with the glass that I already own? Or will I run into a lot of problems?
Old Jun 15, 2018 | 04:04 PM
Car Analogy's Avatar
Can you even still buy a top with plastic window. Why would anyone make one?
Wait, you weren't going to buy a new top from dealer, were you? Way better quality and way cheaper to buy aftermarket. No surprise, its not like Honda has much recent experience with soft tops.
Old Jun 16, 2018 | 11:47 AM
3rdDegree's Avatar
I completely forget who made the replacement top for my car (which needs to be replaced again) but the quality of the top was much higher than OEM, and it replaced the factory plastic window with glass which is way better. It was a direct replacement and I replaced it with my father (it was his car at the the time) in a day. I would not recommend a plastic window, they are foggy and scratch in no time, the glass is still perfect and lasted way longer. The top is the only thing on my car that is not OEM and it is way better looking, better quality, and lasted longer than the stock top did.
Old Jun 17, 2018 | 05:19 PM
2poor2mod's Avatar
if you own a glass window that was removed from another S2000 top, just toss it it’s worthless. You can’t swap a plastic window with a glass one. You’ll need to buy a complete top with a glass window and the retrofit kit to convert your top to a glass window.
Check out www.topsonline.com and the Robbins cloth glass window conversion. I promise you you won’t be disappointed.
Old Jun 26, 2018 | 10:00 AM
twohoos's Avatar
Regarding the OE tops:
- The '00-'01 plastic-window tops fold differently from the glass-window tops, so the frames and cloth are not interchangeable.
- The plastic window is technically replaceable (zips out, but not not readily - it's a bit of a job). New plastic windows were still available a few years ago via a special-order process involving dealer-pickup, but I'm not sure about now.
- The glass windows are not replaceable, they're a permanent part of the cloth assembly; so if the window breaks, only the frame is salvageable.
Old Jun 26, 2018 | 11:51 AM
Manga_Spawn's Avatar
Site Moderator
OP knowing the model year of your car would be helpful. It sounds like your current top has the glass window is that correct? If so I would replace it with a robbins top (I think there is another brand as well but the name escapes me). Pretty sure there all come with glass windows but if not I would by the same as what is on the car currently.
If you currently have the plastic window I would still look into getting a replacement with a glass window. I feel like I have seen other do this without having to swap anything but the top out but having never done it myself I cannot be sure.
DesiS2k
May 22, 2012 11:24 AM
it'S2klean
Jun 22, 2011 03:39 PM
Nmatthews2000
Oct 27, 2008 10:39 AM
S2Karizma
Aug 9, 2006 10:01 AM
SLstone s2k kid
Jun 25, 2006 08:56 PM
