Spal fan relay question
Hello fellow members I purchased only 1 high performance fan and I plan on still keeping my stock AC fan, my question is it possible to wire spal harness to oem harness to keep everything flowing the same ? Just how both fans turn on now when it gets hot and the AC is on ? Thanks kit shojld be arriving next week
I haven't wired in a Spal fan relay myself or any fan relay on the S2000 for that matter, but a relay is a relay: A device that allows you switch a high current circuit, using a low current circuit. You will need to wire up the relay's high current circuit to your battery, then use the OEM wires that used to power the fan to switch the relay.
steamedturtle
Nov 24, 2016 07:42 AM
