Sponsored by: CARiD
Spoon Calipers
Old Aug 1, 2009 | 12:56 PM
f23power's Avatar
Default Spoon Calipers
so i'm in the market for calipers and settled on Spoon calipers. I test fitted my rim on a friends s2000 that has spoon calipers to check for clearance...
my front rim is a 17x7 +38 (5Zigen FN10-R) and the spokes clear the calipers with about 1 mm of clearance.
i wanna make sure that the calipers dont interfere with the rims; (ie heat expansion, hard cornering, etc.) this is my first time dabbling with calipers...will this be enough clearance? should i run a 2-3 mm spacer just in case?
-a
Old Aug 1, 2009 | 01:11 PM
iam7head's Avatar
i mm is not enough, caliper could flex under extreme conditiion, run a spacer to be safe
Old Aug 2, 2009 | 07:44 AM
drexelmech's Avatar
yes, running a spacer would be a much safer, 1 mm might be ok for clearance but its a chance i would not be willing to make
Old Aug 2, 2009 | 10:47 AM
Nickamsweet's Avatar
+1
Old Aug 2, 2009 | 08:18 PM
Mugen112's Avatar
This is interesting. The rims should flex? The spoon calipers have 1mm or LESS clearance with the +35 SW388s. I couldn't even fit a credit card between the two. I never had any problems.
Old Aug 3, 2009 | 10:09 AM
iam7head's Avatar
anything could flex if you put enought pressure to it.
Like i said, it's more likely to be the caliper itself that move out of line, knock back and flexing could happen if you track your car hard enough, i don't know how well is the construction of the spoon binder but i think the wilwood lite binder are known for flexing
Old Aug 3, 2009 | 10:26 AM
Sinji's Avatar
I had about the same clearance with my endless BBK with fn01rc and my ccw and i never encountered any problems even when i tracked it.
for peace of mind i would run a 3mm spacer but i think that you dont need it...
crank
Aug 14, 2008 07:34 AM
PURIST114
Jan 15, 2003 01:10 PM
