Sponsored by: CARiD
spoon center brace
Old Jan 16, 2010 | 10:06 AM
jdsaini's Avatar
Default spoon center brace
I just recieved my spoon center brace bar this week. I went ahead and was going to install it today but i noticed something odd. The two points of attachment for the bar are at a differnet elevation on each side. I am wondering if anyone with an 06 and up have been able to install this bar. It also looks like the mounting points are slightly offset. I just want to know if it can even be installed before i attempt to install it I have seen pictures of 05 and down but not on the later years. This is one of the areas that changed from 05 to 06. I had a similar problem when attempting to install the rear lower gt bar by asm. Any feedback on this situation would be helpful.
Old Jan 16, 2010 | 12:39 PM
gospeedgo1's Avatar
this thing? you can try emailing spoon or opak racing, the US distributor of spoon (spoon japan says if you have any questions to contact dealer).
http://translate.googleusercontent.com/tra...mGFBClmEKHYtCLA
http://www.opakracing.com/
Old Jan 16, 2010 | 02:07 PM
jdsaini's Avatar
Yeah that is it. Thanks for the info. Ill send them an email and see what they say. I was just curious to see if anyone with an 06 and up has tried to install one of them or has one installed on their car.
Old Jan 16, 2010 | 03:31 PM
cenix's Avatar
u talking about the one that goes under the driveshaft?
Old Jan 16, 2010 | 03:47 PM
wisdom's Avatar
He's talking about spoon's xbrace and in the background a problem with asm's lower tie bar.
Old Jan 16, 2010 | 04:36 PM
gospeedgo1's Avatar
i just looked at the link i posted eariler, it says for AP1... the blog does not seem to mention one for the AP2.
http://translate.googleusercontent.com/tra...r7nL-TnwwdgF4kQ
Old Jan 16, 2010 | 09:42 PM
jdsaini's Avatar
[QUOTE]
Yes its the one under the drive shaft.
Old Jan 17, 2010 | 12:34 AM
Nyther's Avatar
I've read that sometimes it's necessary to widen the tunel with a jack to install this piece.. i have no clue if the 06+ have changes made into the tunnel.
If the piece turns out to be mounted on ap1 only, i'll be happy to take it over from you
Old Jan 17, 2010 | 08:27 AM
jdsaini's Avatar
Its not an issue with widening the tunnel. I dont think it was designed for the 06 and up because the mounting points are slightly offset and the mounting points are also at two different elevations. I just wanted to see if anyone with an 06 and up has actually installed this brace.
Old Jan 19, 2010 | 10:29 AM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
^Perhaps the car has flexed in someway where that bolt holes will not line up properly? Just a thought. If you want to sell it let me know.
