Sponsored by: CARiD
Spoon diff
Old May 2, 2010 | 12:30 AM
s2kadrenalin's Avatar
Default Spoon diff
This item is currently for sale in Japan.
I can't help but think, wtf?
When converted to engrish the page reads
S2000 (AP1 AP2) it is the capacity UP diff. case cover of SPOON make which solves the capacity insufficiency of the diff. oil which is the weak point. Because the diff. carrier is modified in those of another model, it exhibits. Including also the one for carry extra, this time 2 you set exhibit.
Because both appearance it is very clean state the scar or the crack without altogether, feeling at rest, please bid.
As for the information where the product is detailed from this
http://www.spoon.jp/details.php?id=827&md=s2000&cid=3
How did they deduct the weak point for our crappy diffs cause as being not enough oil? We all know the axles / brittle crown and pinion are the usual cause for disaster within our diff casing....
Old May 2, 2010 | 08:44 AM
CapoArgentino's Avatar
Banned
You are forgetting the fact that this diff upgraded was intended for severe track use, not for the daily driver
I dont think oil capacity is an issue for normal driving and some track use. I always wanted one of those
Old May 2, 2010 | 08:48 AM
Banned
Here, this is from the Go Tunning site:
Spoon Capacity Up Diff
Old May 2, 2010 | 10:44 AM
Dreaming_S2k's Avatar
That makes a little more sense. I'd be scared of tagging it and punching a hole
Old May 2, 2010 | 11:52 AM
Zoomie's Avatar
pretty trick part. i think the weak point for upping power is the gears, but the failure point for hard track use would be heat capacity and that is what is addressed here.
Old May 2, 2010 | 12:06 PM
Banned
I'd drill a hole on it and plug in a Diff oil temp gauge sender
Old Sep 16, 2011 | 07:33 AM
helpslows2k's Avatar
Hi guys is this worth the money or does it make more sense to go with a diff cooler altogether?
Old Sep 19, 2011 | 10:10 AM
Boofster's Avatar
Why not tap the stock unit and run a hose to a tank or cooler?
$900 just for a casing is a bit excessive IMO.
