Sponsored by: CARiD
Spoon replica diffuser installation
Old May 16, 2014 | 07:40 AM
gabolges2k's Avatar
Default Spoon replica diffuser installation
just got a spoon replica diffuser but need help on how to install it. It comes with two brackets just need to know where they mount too? thanks in advance
Old May 16, 2014 | 08:18 AM
mongomery1234's Avatar
Just curious where did you purchase yours from? FRP Carbon? How's the quality? Thanks!
Old May 16, 2014 | 09:50 AM
gabolges2k's Avatar
i bought it from UnionPerformance2 got it FRP. The quality is not bad at all, has some scratches and some chip but it doenst bother me since its going to take a beating either way.
Old May 16, 2014 | 11:05 AM
lude92_si's Avatar
Should be 4 brackets total to install it ans 2 plates for the side. 2 of them go in the round tube of the frame. There's a hole that will hold the bracket in. The other 2 will mount up where ur OEM bumper exhaust cap mounts. The line up the sides and drill 2 holes on each side through the bumper. Diffuser should have pre drilled holes. Put bolts through and use the metal plates to reinforce the bumper. So screws through diffuser, through bumper lip, through metal plate then washers and nuts. Sorry best I could do real quick. Feel free to pm me if u need help
Old May 16, 2014 | 12:22 PM
wisdom's Avatar
I agree with all of the above. If yours did not come with the 2 mounts for the rear of the diffusers, you'll have to make them. I used worm gear clamps around the round frame rails, that held aluminum strips bent in a "Z" shape. No issues going 100 mph+.
For added safety, use Nylock nuts or 2 nuts. I've found some of mine had loosened up overtime.
Old May 16, 2014 | 12:25 PM
lude92_si's Avatar
Some quick crappy pics to give you an idea hope it help.
Attached Thumbnails Spoon replica diffuser installation-forumrunner_20140516_161747.png   Spoon replica diffuser installation-forumrunner_20140516_161911.png   Spoon replica diffuser installation-forumrunner_20140516_162028.png   Spoon replica diffuser installation-forumrunner_20140516_162117.png
Old May 16, 2014 | 12:31 PM
lude92_si's Avatar
Worm clamps would work too. I just used some poster puddy on the nut and stuck it to my box end wrench and slide it in the rail lined it up and screwed the bolt in. Then removed the wrench, pretty simple
Old May 16, 2014 | 11:43 PM
gabolges2k's Avatar
thanks guys for the help!! i really appreciate it.
CHEESEFRIES333
May 23, 2017 01:35 PM
Tougemon
Jun 19, 2016 03:07 PM
AP_ONE
Apr 28, 2013 10:26 PM
KaJe209
Jan 8, 2012 12:33 PM
artbillgen
May 25, 2011 04:52 PM
