Sponsored by: CARiD
Sway (stabilizer) bars
Old May 21, 2009 | 07:05 AM
nse2167's Avatar
Default Sway (stabilizer) bars
I've been poking around and coming away confused. Some say leave the stock bars in place on my '06; others suggest the aftermarket adjustable; still others suggest aftermarket non-adjustable. . . rear only? front only? Yikes!
Suggestions / feedback most appreciated!
Old May 21, 2009 | 07:35 AM
cdelena's Avatar
The later models are pretty we sorted out and there is no reason to change unless you plan a serious autoX season.
Old May 21, 2009 | 08:17 AM
negcamber's Avatar
What is your goal for the car? Autox; track days; aggressive canyon/mountain driving; just street?
Old May 21, 2009 | 09:01 AM
nse2167's Avatar
My car is strictly street - I was told I could improve cornering w/ aftermarket sway bars.
Old May 21, 2009 | 10:33 AM
cdelena's Avatar
Your car is well configured for the street and changing the bars have a much better chance of hurting rather than helping your handling.
Old May 21, 2009 | 10:34 AM
Blue_AP2's Avatar
I have a S2X strut bar and it helps
Old May 21, 2009 | 10:55 AM
negcamber's Avatar
The suspension is a system...springs, shocks, sways. Some folks do change sways alone, because they are constrained by racing rules (SCCA Stock Class) or because a sway bar change has been tested to eliminate a negative behavior (ap1 larger front sway to reduce oversteer).
If you are just looking to improve handling, it would be better to go with a complete system...like doing a CR suspension swap (springs, shocks, sways). The downside is that the car will have a rougher ride.
Or a tested mod that has shown to improve ap2 handling without compromising ride is to get a set of Bilstein PSS9 coilovers.
Old May 21, 2009 | 10:59 AM
pistolpete17's Avatar
Here is what I did. Second to last post has a "good read" link, read it.
Linky
Old May 21, 2009 | 11:12 AM
INTJ's Avatar
The gang is right. Moreover, the car stock greatly exceeds most driver's ability to corner... Monkeying with the suspension will not make it handle better. I blow people with highly modified cars away with a stock setup. And I am not an expert.
Take the car to an autocross and win your local class. Then we can talk about which mods are right for you. Save your money for tires and leave the suspension alone.
Old May 21, 2009 | 11:17 AM
thebig33tuna's Avatar
http://www.houseofthud.com/cartech/swaybars.htm
^ the link in question
great read.
