Tein Flex user help
Originally Posted by JimiChanga,Jul 14 2008, 09:09 AM
I just had a thought...did you adjust the bottom perch or the upper perch...Doesn't the upper perch adjust spring preload, whereas the lower perch actually deals with height adjustment.
Hmm, not in an S, but I got a ride height lift in my integra after installing OEM suspension. After correctly preloading the bushings, ride height came back down to normal. Maybe the same is happening with these coilovers? If you tightened down the suspension while the car was in the air, that could be your problem. Good luck.
dino4u
Apr 24, 2009 06:07 PM
