Sponsored by: CARiD
Test pipe CEL light
Old Mar 29, 2008 | 02:20 PM
HighwayStar's Avatar
Default Test pipe CEL light
Hey guys i have an 06 with a Invidia 70mm test pipe and the rest of the car is stock. i had it on for about 700 miles and the CEL for the o2 come on when i drive low speed at low rpms. what can i do to fix this?
Old Mar 29, 2008 | 02:42 PM
mic_crispy's Avatar
Have you put the non-foulers on there? If not get two and do that...
But that still might not fix your issues. I have a MY06 and throw a CEL with my Test pipe and non-foulers...
Its just because MY06+ have a more sensitive ECU / 02 sensor.
Old Mar 29, 2008 | 03:10 PM
what are non-foulers? the only thing that i know it has is the hole where the O2 Sensor goes and if you look inside of it you see a the like a small pipe where the sensor goes have a the wool around it
Old Mar 29, 2008 | 04:19 PM
mic_crispy's Avatar
http://www.msprotege.com/forum/showt...hp?t=123634664
Old Mar 30, 2008 | 06:30 AM
Timphan84's Avatar
get non foulers...use them both with a screen/mesh in between the foulers and you shouldnt have a problem. sometimes foulers will still give you a cel. but with the mesh it wont.
Old Mar 30, 2008 | 07:23 AM
icemans2k02's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry11953366
heres another one that i had made helped both of my buddies with my07
Old Mar 30, 2008 | 02:16 PM
littlejap33's Avatar
get a CEll fixer
Old Mar 31, 2008 | 05:55 PM
thesilverbullet's Avatar
i have the 70mm invidia tp. got my first and only cel after 40miles. added a ebay one piece external fix stuffed with steelwool and no cel after ~9mos/6k miles later...
Old Mar 31, 2008 | 06:41 PM
SoMe0nE2tAlK2's Avatar
200 miles with T1R 70mm testpipe on an 08. CEL came on.
EDIT: had 2 defoulders
Old Mar 31, 2008 | 11:56 PM
smirfs2k05's Avatar
I've been lagging on this since cel doesn't bother me much but I'm just going to add a resistor into the signal wire of the 02 lets see if that tricks the ecu. I'll try it and report back.
