test-pipe installed cel is on. help.
i just bought some 14mm foulers, and there too small.... the whole in the test pipe (diameter) is much bigger then the foulers i bought, plus the test pipe i bought was suppose to have the cel fix inside of it, not a extra part, like the pic shows above
need help asap guys please.
There is no cel fix inside. The cel fix the testpipe comes with is the extended nonfouler attached to the pipe.
Unscew the invidia cel fix, screw in two 18mm non foulers, then put the invidia fix after that... then attach the 02 sensor. You'll be good to go.
ill do this mod
https://www.s2ki.com/forums/index.ph...ic=229959&st=0
thanks bro
Marc
Originally Posted by tudernos,Dec 4 2008, 06:33 AM
You have to bore it out to make it fit.
You need to bore out your non foulers if you do not have the invidia fix
Every part screws into itself with the fix.
Got the part today, and had the tech bore and install it, reset codes. Well see what happens when i drive home tonight
wish me luck.
ps: does having the check light on hinder performance? I assume it does since the a/f is going to be way off.
wish me luck.
wish me luck.
wish me luck.
