Sponsored by: CARiD
Test pipe size?
Old Sep 29, 2010 | 06:23 AM
llckll's Avatar
Default Test pipe size?
I plan on getting the Greddy SE exhaust. Should I get the 63.5mm test pipe or 70mm?
Greddy's specs are 70mm to dual 60mm piping. So I'm assuming I should get the 70mm to match up with the beginning of the exhaust which is 70mm for maximum performance?
Old Sep 29, 2010 | 06:24 AM
suzuka-blue-s2k's Avatar
70mm
Old Sep 29, 2010 | 06:26 AM
llckll's Avatar
Would the 63.5mm not match up due to the size difference?
Old Sep 29, 2010 | 06:31 AM
It will match up since the flanges are the same, the only difference is the pipe diameter. (of course the flange has a 70mm opening instead of a 63mm) So you can put any size test pipe on any size catback. It would just be worthless to go smaller than your exhaust size. It will match up with the pipe diameter of your exhaust perfect and maybe make a little more power with the 70mm.
Old Sep 29, 2010 | 06:32 AM
llckll's Avatar
That's what I figured. Thanks.
Also, the 02 sensor just screws off and I should be able to screw it on the built-in CEL fix?
Old Sep 29, 2010 | 06:35 AM
No problem. Yes just un-clip your o2 sensor so you dont twist up the wires, and un screw it. Then just screw it into your new CEL fix on your test pipe and then clip it back in, done!
P.S. The electrical clip is on a little hanger by the tranny. Just look where the wires go and you will easily see it.
Old Sep 29, 2010 | 06:37 AM
llckll's Avatar
and then ?
Old Sep 29, 2010 | 06:39 AM
Old Sep 29, 2010 | 06:40 AM
llckll's Avatar
Old Sep 29, 2010 | 07:27 AM
Mike21's Avatar
either will do.
essentially, you're going from a 60mm header collector to a test pipe, then to the exhaust.... so 60(h)>63.5(tp)>70(e) isn't going to make much less power than 60(h)>70(tp)>70(e).
