Sponsored by: CARiD
throttle body worth it
Old Oct 3, 2014 | 10:25 AM
dsthez's Avatar
Default throttle body worth it
Looking at the skunk2 70mm throttle body. Anyone have experience with it? I have a k&n filter on a stock air box. Everything thing else it stock opinions?
Old Oct 3, 2014 | 10:36 AM
jst2878's Avatar
3 inch intake, 70mm throttle body and port matched intake manifold is what u should muster up. I'd say science of speed throttle body over shit2 throttle body.
Old Oct 3, 2014 | 12:22 PM
YELLOW JACKET's Avatar
have sos tb and makes throttle response better but no more hp unless your fi. nice easy upgrade.
Old Oct 3, 2014 | 12:30 PM
mugen_rsx09's Avatar
Why don't you just get this?
http://www.balladesports.com/product...-throttle-body
Old Oct 3, 2014 | 01:57 PM
thomsbrain's Avatar
The word from my very experienced tuner was that the throttle body and intake manifold are one the last things that will show any gains, after you've done everything else possible. What most people report as an "improvement" is throttle "response," which is simply that the larger throttle opens to a given air-flow rate at lower throttle pedal position. Essentially, you hit "full" throttle at less than full pedal travel, and beyond that the engine is already breathing at max capacity so opening wider doesn't make any difference. So all you are doing is reducing useful throttle pedal range. He said with boring, port-matching, machining the manifold, installation and tuning you'd be looking at $1000 for 2 HP peak if you're lucky. There are far cheaper ways to add power.
Old Oct 3, 2014 | 02:48 PM
dsthez's Avatar
What are the cheaper ways?
Old Oct 3, 2014 | 03:29 PM
superstuddc27's Avatar
Ballade ported manifold and throttle body is cheaper than $1000. but only for non DBW
Old Oct 3, 2014 | 05:12 PM
GS-R Civic's Avatar
i tried the skunk2 and it messed up my idle. on a cold start it would idle at 3k and warm up idle at 2.5k. posted my problem on here and apparently it was a common problem. I went back to stock and it was perfect, then went to sos and 70mm ported intake manifold and it was fine. car made 238 whp on evans dyno and he said every other ap2 on his dyno makes 225 whp. hope that helps. i also have k&n fipk plm header 70mm resonated tp 70mm single exhaust.
Old Oct 7, 2014 | 03:41 AM
Marin3SSgt's Avatar
When I was NA I added a 70mm TB and DIY port match on my05 ap2. It felt more responsive. Now that I'm boosted it was one less mod to do. I recommend saving for a supercharger or turbo kit new/used.
Old Oct 7, 2014 | 05:41 AM
Moddiction's Avatar
Former Sponsor
I added SOS throttle body on my supercharged AP1. I got it only for the pressure seals for meth injection but did back to back dyno's and showed 2 hp gains. I'm making just over 420whp. I thought I'd get a few more than that but luckily I only bought it for the upgraded seals in it.
