Too Lean?
I don't know about A/F ratios but from what I have heard being lean is worse than being rich (forgot why.)
I have also heard testpipe-catback combo makes the ap2 run lean.
So would a testpipe and megans single (2.5") make my car run to lean for it to run properly without some type of engine management?
I have a bone stock 07
2007 + test pipe + single exhaust?
I wouldn't bet on it, take it to get your A/F checked and report back.
70 dollars more to check A/F is far better then detonation and reduced engine life.
My guess would be in the high 14's @ 6-7K
Originally Posted by s2knewbzor,Oct 26 2009, 09:17 AM
Nice guess I'll be ordering those soon then.
Thanks for the quick reply
you'll be "ok", meaning there will not be any short term damage to the engine, but you are adding pre-mature wear to the car though.
this combo will definetly be leaner than stock. lean enough to blow up the engine? no. but lean enough that you are consciously contributing to a problem down the line.
but if you like to get on it and take some spirited runs in vtec regularly you might want to consider tuning.
