TopOneMotors - Front Diffuser / Side Splitters
Im assuming he used the PVC tubing as a spacer or base to tighten up the bolts between the splitter and lip. Basically in order starting from the bottom, Bolt, maybe a washer, splitter, PVC tube, OEM lip, then factory nut.
He can correct me if Im wrong or made it real difficult to understand lol
You can buy a piece of PVC tubing from a hardware store (I didn't need too many but they only had like a 6 ft. version), then just cut even portions so you can use it as a spacer. Otherwise the top of the splitter will literally be on your OEM Lip with no room to breathe which not only looks weird in my opinion but can cause paint damage.
I know it's been a while but I finally got them on. Here's some quick pictures I snapped on my phone!
Just FYI to those who are interested, you will need additional hardware (longer bolts + pvc tubing) in order to install the front splitter if you have an AP2 OEM Lip. The hardware that comes with the packaging was included with just the AP2 bumper by itself in mind.
Do the side diffusers use factory holes instead of self tapping screws? Hard to tell from their website.
@first-s2k
They are self tapping screws. You'll have to drill the holes first.
I'm not going to completely disagree with you, the "Top1" logo is a sticker and I could probably do without it. They make the front splitter without the winglets on the side that look more subtle which I was originally planning on picking up instead but passed on since I had the LowProAero splitter before (similar design). Wanted to try something different for a change, it's obviously not functional aerodynamically in the sense that it'll help you get better track times (ie. APR Splitter w/rods attached to the actual chassis), but definitely functional in an every daily driver kind of way in that it protects the AP2 OEM Lip from getting damaged (my main priority with this to begin with). Not sure I would want to wrap something that will most likely take some road abuse in carbon fiber lol.
Yeah if I remember correctly there were about 14 holes in total.
You are absolutely correct, couldn't have said it better myself lol
