Sponsored by: CARiD
Turbocharging to boost to 350 HP
Old Sep 26, 2022 | 11:20 PM
RolanTHUNDER's Avatar
Originally Posted by SmokeyGatto
bigger turbo, 30+ will give you better gas milage. a smaller constantly spooling turbo will drink it all.
longer gears helps too. i have 3.73's.
look into the ptuning kit, but be forwarned. its easily the cost of the car or more to do it right.
also, i hope your good at problem solving, because it will be a challenge to iron out all the kinks.
happily turbo'd at 350-620 depending on fuel and boost settings, full blown track car thats capable of cross country trips. my last road trip was 5500 miles, best of luck!
Sounds like you've got a good build there. Well done
Old Sep 27, 2022 | 12:53 PM
billios996's Avatar
This has to be a troll post. What retired couple is road tripping the entire north america with a S2000??
Anyway, skip the turbo. Get fresh gapped plugs, fresh air filter, get the taller gears, get a hardtop, get some efficiency tires from a Prius, get a standalone and tune the ECU for efficiency (i.e. stay out of vtec).
Or, go buy a 4 cylinder Camry for your road trip and sell your S2000 to somebody that wants to drive it as designed.
my 2 pennies
Old Sep 28, 2022 | 02:36 AM
BuggyofMildDiscomfort's Avatar
Hopping the car up to 350bhp isn't going to use less fuel, easy as that. Give it a service and make sure the tyre pressures are up and call it good.
Old Sep 28, 2022 | 07:53 AM
Car Analogy's Avatar
It appears his idea is to dramatically raise rear end gear (lower the gear ratio) to improve hwy mileage by lowering revs, well beyond what stock engine torque would allow. Then raise engine torque with turbo, so engine can pull those gears.
This could work. Maybe. But then it adds another dimension to working out the kinks that many here have already mentioned. Plus you'd be going down a largely unpaved road. No one to copy off when trying to plan build, no one to answer questions when sorting issues. Plus if you have trouble on the road...
Most of all, in the end it may not actually improve mpg.
Instead i'd just raise gear ratio a reasonable amount, get a hardtop, and fit lower rolling resistance tires (not prius tires, just something less extreme than the typical summer tires).
You'll probably get 35 mpg hwy or better at reasonable hwy speeds.
Old Sep 28, 2022 | 08:19 AM
That generally only works if you drop the engine size so you get into high load area's with the turbo to take advantage of the energy pulled from the exhaust stream. Hence all the 1.0L turbo engines around in euroboxes lately.
Old Sep 28, 2022 | 09:17 PM
my 2 pennies
This is an angle none of us thought of looking at this thread from
PearlJamMan
Mar 2, 2015 07:22 AM
Ruthless_one3k
Dec 5, 2010 05:07 PM
s2kcrsrt8
Feb 21, 2010 10:25 AM
JuicedS2K
Jul 9, 2009 05:47 AM
Rxmfn7
Feb 21, 2009 02:26 PM
