UK user needs help with a replica mugen hardtop
Bought a replica mugen hood, they are quite rare over here. Anyway I am fussy and new I would need to spend some on it to get it right.
Anyway, can I fit these to it?
http://i.ebayimg.com/t/Honda-s2000-hardtop-rear-catchers-latches-spikes-/00/s/MTAwMFgxMDAw/$T2eC16RHJIkE9qU3kWRdBQO7n8HTYw~~60_35.JPG
That way I can remove it easily like the oem hood.
Also any other tips/suggestions? The seal for the rear screen isn't perfect so may take it or and redo it, then it will be getting painted I think. It's goig on my 2002 jdm white car
Regards and thanks
Regards and thanks
So I can fit oem ones? I have an oem hard top too I could take the catches off that and them sell my oem with the brackets I will be getting from the guy I bought the mugen off
It has the oem front hinges fitted
they are interchangeable. meaning oem/replica hardware can be swapped around. the holes are in the same spots.
theres 6 pieces to the oem latching hardware. the 2 front latches, 2 catchers on the car side, and 2 rear latches on the hardtop side.
aftermarket rear hardware is usually a metal bracket that replaces the 2 catchers on the car side and the 2 rear latches on the hardtop side.
^replica tops usually come with the rear brackets and you reuse the 2 front latches from your soft top.
hope that helps
hope that helps
jXxviii
Jan 2, 2017 07:57 AM
The guyver
Nov 13, 2014 07:18 AM
